So far so good. Took like 5 weeks or so for SPD to make the pipes. They did some serious custom welding to make it similar to factory.
The quality of the Stainless Works pipes was seriously awesome but the fit wasn't that great. For instance, the pipes are completely separate and not welded together where they converge and connect to the exhaust. This resulted in a light rattle on mid throttle. The pipe also hung a bit lower than the factory pipes. Even though I had no issue with the low hanging pipe getting beat up offroad, I still think this should have been fixed. Also, the Stainless Works pipes eliminate the turbo adapter. At first I liked it, reduce bottlenecking. But.....since the pipe bolts directly to the turbo and the exhaust flexes while offroading, there were two instances where the flange bolts backed themselves out during heavy offroading (even with threadlock) and the downpipes were super loose.
The SPD pipes have a welded section where the two pipes converge. This eliminates all the rattling I had before. They are mounted higher and they use the turbo adapter. The icing on the cake was that they use cats that don't throw check engine lights. It was a no brainer for me.
The downside to SPD pipes are they are made of aluminized steel. I guess it has the potential to rust quicker than stainless. I'm in AZ though so I don't have to worry about rust.
