Stage 2/2+ Hard Parts and Off The Shelf Maps Now Available!
cwylie
Anyone having any issues with the fitment on the downpipes? They dont line up without tension applied and when forced to line up it hits the heat shield. Shop called Cobb and their response was well it might rattle. I dont think a rattle is acceptable on a $1400 part.
FmaxTurboSi
So Cal
Curious as to how they sound!!!
texasflyer
The shop that installed my Cobb downpipes said the first time they bolted everything up, it wasn't clearing the heat shield so they had to loosen some of the bolts a little to get everything centered before retightening all the bolts. I'm not experiencing any rattle with it installed.
With DP installed and stock cat-back exhaust, cold starts are a little louder, heavy throttle is much louder, idle or cruising at low RPMs is basically the same as stock. When I first got it installed, I kept thinking I left my rear window open. Overall sound is definitely deeper and a little throaty under throttle. If you're looking for a real deep V8 sound, you'll probably be disappointed. I didn't get the DP for sound, mainly to squeeze out a little extra power for future performance mods and tuning, but I like the way it sounds. If your goal is to wake up the neighbors, I'm sure pairing these DPs with a cat-back exhaust would go a long way.
JohnyPython
Canada
Just noticed that there’s a coolant reservoir cover. Looks awesome!
Do you need to flash stage 2 and what gains we looking at?
