ok so the only negative i have seen with this... if the valve fails you lose your brakes.
other than that, they are neat.
NO. Remember, even normal valves have to be loosen to be bled. When you loosen it you are essentially moving the valve up and out so that the hole in the valve is now in the channel where the brake fluid can flow out. When tighten down the hole in the valve is below the channel and this no fluid can flow out.
