SPD Catted Downpipe
k-rub
Tucson, AZ
Hard to tell because I did exhaust at the same time. But I could feel a difference after putting both on compared to stock.
kpg81
SoCal
The default cat they use is only a 400 cell.
Factory is 500 cell, most likely.
There's probably very little power gain with a 400 cell cat, you should be using minimum 300 and ideally 200 cell. I think getting it with 400 is a waste of money
M3LELENA
MDG
isnt 300 & 200 cell gonna throw a CEL
r8ders
From my experiences 200 cell HFC will more then likely throw a CEL in the newer cars/trucks. Some vehicles systems are more sensitive than others. You may get lucky but it seems Ford and Audi's emissions systems are pretty sensitive from what I've seen on forum post and experiances
Even with an O2 extender my wife's car throws the occasional CEL when the engine has a heavy load (AC on a medium setting and getting on the gas). I picked up the Vibrant 11619 J-Style Oxygen Sensor that has a adjustable flow and will see it that helps w/ the CEL issue.
kpg81
SoCal
Yeah, O2 extenders always work.
No reason to not use 200 cell cats or you are just wasting your money for very little HP gain.
ATRaptor
Can you be specific which extenders?
O2 extenders are often times referred to as defoulers and basically pull the senor a little further from the 'stream' to trick the 02 sensors. They come in many shapes and sizes and can be had for around 20 bucks, give or take.
nikhsub1
Los Angeles
Yes i know exactly what they are... when i asked him to be specific i meant with a model number of a particular spacer since there is usually one that works with well with a given downpipe.
96,484
60,438
BayCityBomber
