Spark Plug Warning
R
rbarn
PB Blaster is just a brand name for penetrating fluid helps loosen up rusted up bolts. It wicks into the threads and helps release them.
R
rbarn
And neither would have made a wit of difference to the problem I am addressing. The factory puts the original spark plugs in dry. This is a big no no in my book. ALWAYS put anti-seize on spark plugs.
fordfan
Kane PA
Be sure to use high temp nickel anti seize and actually the plugs in the 3v engines foaming Carb cleaner actually loosens the carbon build up on the end of the plug. We break them loose, soak with Carb cleaner and then remove. When the plugs come out making all kinds of creaking you know the whole plug is coming out. When the don't make any noise chances are you have one broke off in the head.
naimad
So Cal
Kroil is probally the best stuff i have ever used i need to try the atf acetone 50/50 mix
got this info off another sight penetrant average load
none 516 ft lbs
wd40 238 ft lbs
pb blaster 214 ft lbs
liquid wrench 127 ft lbs
kano kroil 106 ft lbs
atf acetone 50/50 mix 53 ft lbs
SwampKing
PB blaster is the Chit! Used with great success on my end. I refer to PB blaster as WD-40 on steroids only bc it has worked for me better through my years of motor swaps, ect...
fordfan
Kane PA
Well back to the original topic of plug removal, I just pulled all 16 to instal cooler NGKs with a supercharger and they all broke free and spun out with no problem at all. I broke them loose and then spun them out by hand. Not sure why rbarns came out so hard
