Some engineer is going to get fired
Sage
WA, dry side
Finally after 10 years, I've had a part on my gen 1 fail. The wiper switch went screwy. It took 20 minutes to change it. Would have taken less than 10 if I didn't have to look for the correct socket and torx tools.
I can't believe Ford allowed an engineer to make something that simple (5 screws, slide out). Must have been a new kid that hadn't had on job training yet.
Had I taken it Ford dealership:
Parts = $165.00 (paid $25)
Labor = $ 150.00 (15 minutes)
Good on you. I owned a Kawasaki ZX11 for...15 years. I did all kinds of things to that bike, she still put down over 150 at the wheel on year 15. Anyway, that was the year that the only failure ever occurred for me- the front brake switch that turns on the brake light.
It’s the exact same part on every road going Kawasaki for as far back as they have records! On a bet, I pulled the one from my ZX14, and sure enough, it worked. cost less than 10 bucks to replace.
Ruger
Northern Nevada
The "engineers" who should have been fired are the ones who declined to put drain plugs on differential covers, and the ones who put plastic pans on the engines and transmissions of America's premier off-road vehicle. The guys behind the cam phaser debacle ought to be out the door, too.
