soft front springs?
wjbradbury
raptor soft front springs
love my raptor, but it feels like the front springs are too soft off road. Even in relatively small whoops, or small berm road crossings i bang the front skid plate. Can I adjust the preload on the springs to stiffen up a bit? Anyone else notice the same thing?
GRT4DRT
middle or top perch will do that for ya...top=firm... just watch out for g-outs! :peace:
W
wjbradbury
Even in relatively small whoops off road, and at fairly slow speeds I keep banging the front skid plate, like the springs are letting the nose dive into the next whoop. Any ideas?
Hockster
My 45ft Bluewater Party
Winchester, Va
LOL... You join here today, make 3 posts all about the soft springs on your Raptor...
SDHQ GOODGUY
AS THE OTHER GUYS HAVE MENTIONED, THE SPRING PERCH ADJUSTMENT,
HERE IS A LINK THAT WILL HELP YOU, WE ALSO HAVE THE ALIGNMENT CAMS YOU WILL NEED IF YOU GO TO THE TOP PERCH
Adjusting your front Fox Coil-Overs
LET ME KNOW IF I CAN HELP YOU WITH ANYTHING FOR YOUR RAPTOR
BIRDMAN
Birdministrator
Boston
The perch mods don't change the spring rate, they just add pre load which will cause a more harsh rebound not necessarily any stiffness.
Rat
Well-Known Member
under the 3rd st bridge
Did anyone know 5.4 Raptors have a different Front spring rate than 6.2 Raptors ?
And has anyone looked into a stiffer spring rate for the 6.2 Raptor front ?
just an idea
darkhill240
just an idea
no replacements availible. it doesnt use the standard coilover spring, it uses the oem spring from the parts bin
