Smittybilt 10 lbs Black CO2 Tank
Deleted member 12951
Guest
I had mine in the back of my truck all summer (have a roll-x) and outside temps where in the upper 90's and didn't have any issues. Perhaps contact Smittybilt directly and we can ask.
SilentShooter
Siesta Key, FL
CO2 in very cold temps is not that useful. You would want to warm the tank. Either keeping it a warm truck and putting blankets and towels around it when you use it or a warm bucket of water.
As for heat. The warmer the tank the higher the Pressure. At 88 degrees F the contents are 100% gas. Long as the tank was properly filled and not over filled it would require the tank temp to reach about 150-155 degrees to reach the 3000 psi which is what the burst disk is set at on most CO2 valves. At 122 or so degrees it should be around 2000 or so PSI.
So basically long as you keep it out of direct sunlight on extreme heat days and away from any extreme heat sources it should be ok. Also as you use/vent the tank its temp will drop dramatically.
If you are running in the desert when its 118 out and sunny I would make sure I had it inside something or a light colored cover over it.
SilentShooter
Siesta Key, FL
If you keep it outside the whole time and do not warm it. Most guys I know in extreme cold have bottle blankets that plug into the 12v and warm the bottle
Guest
I also have a backup that I carry with me. The smittybilt 2781, 5.65 CFM
And I do not care much for ditches.....
Wilson
South Dakota
I k ow you run hard if you do it will happen. Well more likely anyhow.
---------- Post added at 08:02 PM ---------- Previous post was at 08:00 PM ----------
Some day when I have all kinds of money I'd like one of these tanks.
