Smashed LCA mount
Deleted member 12951
Guest
That's cool!! Wish I lived closer to KHC. Wonder it is works with the CAM kits.
SDHQJASON
Gilbert, Arizona
This is a very common issue guys who really push their trucks run into. Like others have said, a BFH or a pry bar is the best way to get it straightened back out.
We have come up with some reinforcement plates to prevent this kind of damage from happening. They are welded onto the stock lower control arm mounts to double the mount and make it much stronger. This will work with the stock lower control arm bolts or if you have a set of alignment cams, we offer longer Metric bolts as well.
SDHQ Raptor Lower Control Arm Doubler Plates
SDHQJASON
Gilbert, Arizona
So essentially you are increasing the thickness of the tab which of course requires a longer bolt.
Yes, Sir. You are correct.
Staff online
97,067
61,001
OffroadWagon
