Skid Plate Using Control Arm Bolt
Z
zmiles308
VB/STA
Thanks for the advice.
Stock UCAs.
I'm going to drop the skid plate and install a caster camber kit.
Fabricating brackets is out of my wheel house so I will see what the local shop can do.
Rick at FMS
aka:Rick @ FreedomMotorsports
SW Virginia / SW Missouri
Stock UCAs.
I am amazed that they got the alignment correct with no room to make any adjustments except for toe.
These are the cams you want. I ran these for years and they never moved even with 4 trips to Baja and other rough off-road trips I did. If the shop is getting these, then great but if you need a set, you can get them here or message me for a discount
