Silver State Run - 2016 (March 18-20)
schmeal
Reno, NV
This sounds like an awesome run. Have you pre-ran some of the sections? How gnarly is the terrain?
When you say "Run" how much faster will the pace be than say, poker run II?
m3dragon
m3dragon
Orangevale
Close to same as poker run but some rougher sections and of course longer.
I forgot you get that bad boy upgraded with shocks? You would want to get longer travel or at least bypass's as the long use will cause them to fade. Long days being bumped around is no fun.
schmeal
Reno, NV
I've got remote reservoir shocks front and rear so i don't think fade will be an issue. My short comings would be running a 33 inch tire and only having 10 inches of travel. Sounds like I should sit this one out.
m3dragon
m3dragon
Orangevale
Nope you are good. I thought you upgraded but I could not remember what.
And you know how we run so you are all set. Sign away.
vanilla_gorilla
NorCal (Sacramento)
Come on our Neal, you should do fine.
Just make sure you have the 50 watt Radio and a GPS tablet or Lowrance...and maybe some tires, can't remember if you upgraded tires or not from the stocks.
schmeal
Reno, NV
I've got the FOX DSC reservoir shocks front/rear with camburg UCA's and the Deaver +2 springs out back. Tires are Bridgestone REVO's one size up from stock. They got pretty shredded from the last poker run. I'm definitely going to bring 2 spares. Radio is installed but not programmed, going to need a hand with that one.
Driving Reno to Vegas is something I've always wanted to do. With a group is the safest way to play it. How many trucks is the cap?
