Sidetracked Offroad LED
SideTracked
Folsom, CA
Has anyone tested on what lenses go good with what? Looks like the ambers are good with the diffused?
Although a lot of people like to run them on the floods, I think they work a little better with the spot pattern lights. The amber lens will cut the light output a little bit and the spots seem to be able to shine through it a little better. Not a huge difference though either way.
2014 Rapture
I have the amber floods and they work great. I run them as running lights 24.7. Here you can see the difference between amber and clear.
matrix243
Calgary, Alberta
I'm not sure this was the problem that was brought in the thread but how's everyones pods sitting in the opening? It looks like because of the curve of the opening, the outside pod is connecting at the bottom edge of the opening. I did dremel a slot in the U bracket so it's adjustable vertically, but doesn't look like it can be tilted for adjustment. If the mounting bracket had less of a drop down if would probably fit better.
You can see that the left pod I had adjust up, compared to the right, but still doesn't clear the bottom.
---------- Post added at 04:09 PM ---------- Previous post was at 04:09 PM ----------
okieff218
okieff218
Oklahoma City
I have the exact same issue with mine.
matrix243
Calgary, Alberta
Never mind. I figured it out. The U bracket can be rotated so the pods sit farther forward. I didnt even realize that bracket had a slight angle to it. All is good.
okieff218
okieff218
Oklahoma City
Best wife ever got me a 20" radius bar for Christmas! Just waiting on them to get more in. The radius looks great and Morgan says it fits the rigid bracket too.
okieff218
okieff218
Oklahoma City
Got the 20" radius bar installed yesterday. Looks great and fits really nice. Looks much cleaner than the straight bar. Morgan with Sidetracked also sent me instructions from another customers mod. He cut the lower grill piece out and reinstalled it to hide the tabs on the bottom. Really cleans it all up and makes it look like it came from the factory that way.
96,628
60,613
shaunsm
