Shift Delayed, Pull Forward 2012 SCREW
NMBoondocker
NMBoondocker
Los Alamos, NM
That particular part you linked says it doesn’t work with a 12. I’m not sure why they are different.
Dane - yes, 4wd and the iwe’s are working as normal.
Sernas
My 2010 call for 600-928 newer models call for the part number you installed.
Curt Kautsch
North Texas
Tim I'm having similar issues. I replaced the TC motor but it has trouble shifting to 4L, 4H works great (i deleted the vacuum IWE system so I know its not that) Any advice? Was it the torque spec that fixed it? ...cant imagine....
Thanks for your advice in advance....
NMBoondocker
NMBoondocker
Los Alamos, NM
Curt - I reduced torque on the TC motor until all selections worked fine. It took about 15 minutes of crawling underneath the truck and back in the cab. But yes, that was what worked for me.
Curt Kautsch
North Texas
I can provide some input here. Either one, or all of the below fixed my very similar problems discussed above:
1) I replaced the TC motor. I adjusted the torque spec to the required 89 in. lb. on all 4 bolts (i think this is critical)
2) I would suggest this to everyone. REMOVE the IWE system all together (Even you Gen 2ers). I understand that it may cause minor premature where, but Ford is the only manufacturer with this system to gain as little MPG to appease the EPA (to my knowledge). The system is garbage and needs to be gutted. (I suggest RCV rings for this $150/pair). 1 hour job if you are mechanically savvy at all.
3) User Operation and sequence of engaging 4L is critical as well. First come to a COMPLETE stop, even letting the motor and gears to spool down completely while in neutral. Second, shift in to neutral (if the cluster indicates "shift delayed, pull forward" DO NOT shift to drive as this confuses the system. Give it a few seconds to engage, and lastly and most important DO NOT depress the brake at any time as this will also disrupt the sequence and it engaging properly. Yes you will hear a slight "clunk" when engaged, this is normal. Follow the same procedure to disengage.
Hope this helps someone....
