Sh*t falling off Brand new truck. No big deal.
PS94
Grande Prairie Alberta
So, what all has simply fallen the F**K off your raptor? So far to date, I lost my left bumper pad cover, my power steering cap, and the heat sheild for the front Driveshaft. I love shelling out $66,000 CDN to have to pick my truck up off the road then buy replacement parts because warranty doesn't cover stuff if its laying on the ground somewhere....
Hockster
My 45ft Bluewater Party
Winchester, Va
Hmm, I had the front bumper pad covers fall off and they were covered under the warranty..
Madcowranch
Genetically Modified
OK
Yeah my bumperette fell off after I nosedived into a berm. My fault though.
Think maybe somebody may have tapped you in a parking lot and broke the tabs?
Budguzler
Winnipeg
I guess Quality is job 1 no longer in effect. I bought mine used,so I couldn't kick the tires.So..when I finally got it it was almost funny how the F$#@k do you miss not seeing the obvious ?None of the under hood rubber bumpers were installed,all sitting on top of the rad,both abs sensor wires not attached to the attach points,one of the front drive shaft bolts not tightened ( lock tite still visible on threads ),passenger seat bottom cover plastic latch thing not clipped on,that device between door hinges (thick black plastic arm )finger tight on all 4 doors.I'm sure there's more I haven't found yet.I ran the vin later to discover it was built on a Friday.If you have a choice/option Don't buy any thing built/made on a Monday or Friday
PS94
PS94
I was able to find the bumperette, all tabs were fine....But I had to remove the bumper to get the pad off, then re-attach the cover....there were no scuffs, marks or broken tabs. on the Heat sheild, there were no marks on the threads where nuts would have ran up past finger tight...
Power steering cap, i was able to find it, but it was all dickered. they fit pretty loose, so i make sure mine is tight whenever i take the truck out...:/
How'd you find out the date of MFG budguzzler?
