Self Levelling Head Lights Adjustment??
121x
ON, Canada
I have the 1.5" RPG front level kit and the self levelling head lamps. When I start my truck manually, I can see the head lamps go through their range of motion. However, when I remote start the truck, I cannot say that I notice this occur. I suspect it does but would like to confirm. It is not uncommon to get flashed by typically 2-3 cars at night. I almost always remote start though. It happens often enough for me to suspect something may be out of alignment.
So my questions are. Has anyone had to manually adjust their self-levelling head lights after a level? Secondly, does anyone happen to know if remote starting, for some reason does not cause the calibration routine to run?
I am trying to determine if these are just drivers (small SUV or cars) being ignorant to the fact these are just bright lights to begin with (not high beams mind you, I seldom use them) and after all, they are sitting 2 ft off the ground. OR, if it is possible that for whatever reason my lamps may need some manual adjustment, assuming it is even possible with the auto-levelling setups.
Thanks
ToadSmasher2K1
Home Is Where You Make It
KC
Thanks
I adjusted mine, they were pointed at the ground for some reason. It’s very easy, Phillips screwdriver from the top of the light
Booth9999
Idyllwild
The lights are bright, not using the high beams gives the impression that your not dimming your high beams wear as when you flip them to low they know they are your low beams. It happens to me too when I don’t use them on single lane roads.
HighwaySentinel
︻デ┳═ー - - - - - - -
California
Like said above, adjust from the top with a Philips head screwdriver. The lights go through the adjustment routine once you press the start button after remote starting.
kandewinn
I have no level and I still needed to adjust mine down. They were way too high.
