SDHQ Front Bumper Hook Up....
SDHQ
GILBERT, AZ
Ok guys... here is the SDHQ front bumper hook up thread! Get em while the gettings good! These discount prices won't last forever....
We aren't always the cheapest.. But when you take a look at our features and our fit and finish, you will see our work is second to none...
These packages include the bumper, lighting, powder coat, paletizing and all the features listed below.. All that is left for you is the truck freight and the installation!
Both of these bumpers feature -
4130 Chromoly construction standard
The main 2" tube is radius bent with 4 additional standard bends to fit the front of the truick
Completely TIG welded
Aluminum 3/16" skid plate w/ stainless mesh insert
We add a structural support bracket for the lower grille valance
Maintains the factory dust guard & factory skid plate
Includes grade 8 hardware to attach to the frame and support brackets
Stainless hardware for the skid plate
Easy bolt on installation
Your choice of powder coat
Signature SDHQ fit & finish
SDHQ
SDHQ
GILBERT, AZ
Our 4 light bumper includes -
The light hoop is radius bent with two compound bends
Tabbed for 4 lights (up to 9” diameter)
Radiused upright supports between your lights
Adds 8" to the front end of your Raptor
SDHQ
SDHQ
GILBERT, AZ
Your lightning options -
Xtreme Halogen Package
(2 Euro Beam & 2 Spot Beam lights)
Specs (each)-
6.25 lbs
1800 Lumens
Oversized bulb for 50% more light
8.33 Amp draw
Die cast housing
HD filament for longer bulb life
Bulb lifespan 400 hours
35 Watt HID Package
Specs (each)-
6.60 lbs
3500 Lumens
2.92 Amp draw
Die cast housing
Internal ballast & starter
Multi voltage 9-32v DC input
Bulb lifespan 2500 hours
Lifetime warranty on ballast & starter
50 Watt HID Package
Specs (each)-
6.60 lbs
5000 Lumens
2.92 Amp draw
Die cast housing
oscthumb.php
oscthumb.php
oscthumb.php
oscthumb.php
oscthumb.php
SDHQ
SDHQ
GILBERT, AZ
Our LED bumper includes -
Tabbed for either the Vision X Reflex or Evo Prime LED bar
Protective top hoop
3 Protective LED guards
Adds 5 1/4" to the front end of your Raptor
SDHQ
SDHQ
GILBERT, AZ
Your lighting options-
40" Reflex LED bar
18.33 Amp draw
10.10 lbs
40.60" in length
22 10 watt LEDs total
Outside 4 LEDs are 35 degree wide beam
Inner 18 LEDs are 10 degree narrow beam
88% optically pure
Driven at 80%
15840 Lumens
Lifetime warranty
39" EVO Prime LED bar
Integrated electronic thermal management (ETM)
PWM Integrated dimming circuity
Advanced heat sink design
20.00 Amp draw
14.55 lbs
39.10" in length
24 10 watt LEDs total
Outside 4 LEDs are 40 degree wide beam
Inner 20 LEDs are 20 degree narrow beam
90% optically pure
Driven at 90%
20640 Lumens
Lifetime warranty
SDHQ
SDHQ
GILBERT, AZ
And now the pricing....
4 light bumpers -
Halogen light package $2095 Regularly $2425
35 Watt HID package $2765 Regularly $3321
50 Watt HID package $2920 Regularly $3525
Make the Vision X housings chrome $320
Led Bumper
Reflex package $2695 Regularly $3244
EVO Prime package $2972 Regularly $3614
