Sdhq ford raptor rear frame reinforcement kit
SDHQ GOODGUY
CHECK THIS OUT, IT IS A INEXPENSIVE PIECE OF INSURANCE
Here is our install instructions Install Instructions for SDHQ Ford Raptor Rear Frame Reinforcement Kit for our reinforcement kit SDHQ Ford Raptor Rear Frame Reinforcement Kit
After seeing the rear frame bend on the Raptor, we came up with an easy bolt on kit that will help eliminate that.
Feature & Benefits -
Helps eliminates the factory weak points in the frame @ the factory rear bump stop
Our kit fully boxes in frame around the factory bump stop mount
Adds vertical support directly above bump stop
Ties the frame and bump stop together
Helps stop the lower frame from getting pushed up which allows frame to fold
No drilling
Uses factory holes
Completely bolt on
Easy 20 minute install
Grade 8 hardware included
Powder coat finish
BigJ
Website says $100. Seems reasonable to me.
MagicMtnDan
Magic Mountain
Nice, simple idea and good execution. Does this kit require relocation of the factory bump stop using your "other kit" with the new cross member?
