Ok so I finally had a chance to install my super duty headquarters abs guards and brake lines. Before I get to the pics and install notes I think might help, I must say the lines firm the brakes up nicely. The lines are top notch as you would come to expect from sdhq. BIG thanks to Ryan for hooking me up with a sweet deal.
So here are the abs guards. Basically I took a pic of the bolt you need to remove to install them. I left it partially unscrewed to help identify it. Then I posted a pic of the guard installed.
Left front:
Right Front:
Left/Right Rear (both are same):
The first picture for the brake lines is the right rear bracket. I found that if you used the stock location hole the stock line would not be the right length. What I did rather than trying to stretch the stock metal line, I used a bolt and nut in the oblonged(spelling?) hole next to the thread oem location as you will see in the pic.
Now you will see the right rear full view
Left rear
This is the left front with the supplied clamp.
Right front
As a side note. I took the time to bleed each line out after installation to lessen chances of getting air all through the system. It may not have been necessary. It did take a little bit of time to get it bled out, but the results are well worth it.
