I"ve been a boondocker RV owner for 40 years with lots of experience with charging and battery power.
1. 4- 6volt battery bank
2. Smart charger at least 45 amp. preferably 55-65 amp. Smart chargers will keep you batterys from being over charged and when you are charging them with what ever system you use, generator or solar it will charge the at the peak rate of the amperage rate.
55 Amp 12 volt Smart Battery Charger by Powermax
3. buy a small generator, 2000 watt to use as a charging. You never have to worry about the sun not being there and the huge amount of panels you'll need to put on the roof, ie, big bucks. Usually an adequate solar system will cost between $2k and $3k. Generator $1k max. I use a little Honda 1000 watter that runs my dedicated smart charger for my batterys.
4. put dedicated 110 outlets from a 3000 watt inverter to run your entertainment center, microwave, toaster, coffee pot and if women are present their hair dryer. don't try and run them all together though.
3000 Watt Power Inverter GFCI, ETL Certified by AIMS
I run my little generator all day or through and tank of gas to keep the batteries charged and hardly use my big generator at all except of evening with just about everything is on for cooking, showering, watching movies etc.
smart chargers where the best thing invented instead of just convertors which I'm sure you have probably in your trailer.
This type of system has worked very well for me. I have used this on over 10 different RV's I've owned over the years.
Also. don't think that your truck is going to do a full charge on your batteries when your driving out to play and if you haven't charged them up before you leave. That is a big mistake usually. Deep cycle batteries take a long time to charge.
Have fun camping.
Mil T
