Running board coating repair
Gus00SVTL
New Jersey
Thanks.
I'm thinking of going this route with the gorilla glue and 3m. How's yours holding up? Could do this for about $40 which I could afford right now.
The U-pol is pricey in canada and hard to ship chemicals across border.
It's holding up great. No signs of it peeling anywhere.
matrix243
matrix243
Calgary, Alberta
Passenger side done. Did have a small 2" section lifting on the side but got it pulled down with some JB weld 2 part urethane which I've been trying to find.
Looks so good I'm going to do my brackets too.
matrix243
matrix243
Calgary, Alberta
For anyone doing the same, don't waist your money on sandblasting. Did not go well. Just stopped trying right away and paid the minimum. Probably would have been 1 or 2 hours. Paint stripper does work awesome though.
tikka
Matrix243 - where did you get the boards resurfaced? So did you use chemical stripper, manually pull of peeling? Up in Edmonton area.
matrix243
matrix243
Calgary, Alberta
Little late but I went to tyro coatings in calgary. Yep, chemical stripper first and just peels off. Coaters mention they still need beadblasting to get a course surface.
matrix243
matrix243
Calgary, Alberta
Update: Realizing now that prep is very important. I did bead blast but apparently not enough because the brand new coating looks to be lifting from rust underneath.
robinthepilot
Maybe you should just get them powder coated. I had a set done here by Regina for $100. That included the blasting.
matrix243
matrix243
Calgary, Alberta
Update- I got them mixed up. Driver side I had done and still look great thank god. Passenger side I touched up now starting to lift. Totally sealed, bubbling, punch a hole through and a whole bunch of salt or white powder underneath. How is that possible?
Pyro3601
Lethbridge Alberta Canada
Both my side steps where peeling real bad on my 2012. 3/4 or better peeled right off no issue. I stripped them down and had Line-x here in lethbridge (actually closer to coaldale) re coat them. Charged me 150.00 so spray both sides. Did a bang up job. Two years later still solid as the day I got them back
matrix243
matrix243
Calgary, Alberta
That is extremely cheap.
