Capt_Holstein559
Not sure if anyone has posted pics of this already but here is what I did to run 37's with stock fenders on top perch...
Pic1-Hammered pinch weld
Pic2-Trim fender
Pic3-Should look something like this
Pic4-Fender lip before
Pic5-Fender lip after
Also, do the rear pinch weld just in case especially with true 37.
This mod allowed me to go hard in pismo and the worst thing that happens is the fender trim will pop off. Not a permanent fix because tires can/will knock off the trim but your tires fender and rest of truck will be safe. My suggestion is if you want to play hard and not buy aftermarket glass just take off the trim for wheelin then put it back on for the street and you shouldn't have any issues. I will try to post a video of a jump when the trim survived and when it didn't. Oh and if you're going to do this make sure you test it out before any real offroading. Every truck and setup is different. I have 37/13.5 r18 toyos with 18/9 +18mm offset wheels.
Pic2-Trim fender
