GEN 2 Rubbing on 37s w/ RPG 1.5 collars. Tips on cutting fender flares
Slaughterhouse
Inland Empire, CA
Glad someone said it before me. But offset has a lot to do with it.
---------- Post added at 01:19 PM ---------- Previous post was at 01:09 PM ----------
Here is an updated pic with the 38x13.5 20 and diberti fenders. Yes, if you plan to play with it off-road, fenders are needed.
If you decide to cut then shoot me DM and I can send or post pics of where to cut.
Damn she thick. You going to do the bedsides?
iceman7273
Nor Cal
Is anyone rubbing on their driver side rear fender ? My driver side bedside keeps rubbing and popping out of the knuckle.. I have a 18 screw with 17 methods and 37 nitro ridge grapplers
I've heard of guys rubbing at compression with stock leafs. Go with a set of rear deavers. I went with +3 and have no rub
BlueGoliath96
•37x12.50r17 Mickey Thompsons Baja Atz p3
•Adv Fiberglass 2inch flare 1inch rise both front and Bedsides
•Fox3.0 Adjusted to the highest ride height equivalent to top perch (overall truck is lifted about 3.5 inches with the tires
• Rear Deavers +2 with the factory blocks
• total chaos Stock UCA replacement
No cutting /trimming whatsoever to clear 37s
Tanner Case
Atlanta, Ga
I ran Toyo MT 37x12.5x17 on factory beadlocks! 3” RPG collar! Zero rub in everyday use. You plan to wheel it you need fenders period!
Love your setup. How is the ride with the 3" collar? I have 2.25" RPG collar coming this week and 37x12.50x17 ridge grapplers to go on my oem wheels.
Members online
96,267
60,138
raptor jp
