ROTO PAX products
RSiWORKS
S.C.S. Michigan
RSI WORKS LLC
Now offers ROTO PAX products.
RotopaX ARE THE ONLY EPA AND CARB COMPLIANT FUEL CONTAINERS AVAILABLE FOR SALE IN THE UNITED STATES! THIS IS THANKS TO A PATENTED THREE LAYER ROTO-MOLDING PROCESS, ALONG WITH SPECIALLY FORMULATED PLASTIC BARRIER MATERIAL TO MEET THE GOVERNMENTS NEW EXTREMELY LOW PERMEABILITY REQUIREMENTS. Who are we?
RotopaX (patent pending) are proudly made in the USA by the original manufacturer of the 1st generation fuel and water packs. RotopaX are Rotational Molded - the process which produces indisputably superior products.
What are the benefits of rotational molding?
Our roto-molded products have distinct advantages over any blow-molded containers on the market today. Blow-molded products, such as cheap “gas cans,” are less expensive to produce, but they tend to color fade, are less durable, and may be prone to additional defects such as leaking. RotopaX, on the other hand, provide the following benefits:
Durable: thicker walls and stronger construction helps RotopaX work and play as hard as you do.
Colorfast: bright colors that are less prone to fading ensure the longest-lasting fuel containers you’ll ever own.
Leak-Proof: extra threads, thicker walls, and a sure-seal gasket guarantee your spout wont leak or vibrate loose
Why are RotopaX superior?
It should be obvious by now, but here are more reasons why you know you want RotopaX. And don’t forget, we also offer a full-size, 4-Gallon gasoline pack - just like we’ve always made but with our new design improvements.
Customizable Flexibility
RotopaX is an exclusive, modular system that allows you to customize 2 Gallon packs according to your varying needs. It takes only seconds to switch between:
Gasoline
Water
Diesel
Kerosene
2-Cycle
Emergency Packs
First Aid Packs
Utility Packs
Unlimited Uses
The wide array of products and the flexibility of the RotopaX system opens additional applications beyond ATV/UTV such as:
Gasoline
2-Cycle
Water
Emergency Packs
First Aid Packs
Kerosene
Utility Packs
RV
Workshop/Factory
Marine
Landscape Maintenance
Home/Farm/Ranch
And much, much more...
Effortless Mounting
RotopaX utilize widely-available mounting brackets which make mounting and storing your RotopaX even easier. And remember that our packs can be used separately as well.
Please contact me personally via PM or email
[email protected]
:head3:
