Rogue Rebel + Baja Designs ONX6 ARC = no bueno
F
Floyd91
If you look at the back of the light, how much room is there between the end of the fins and the frame horn? And can you measure how much it sticks out on the ends? Just wondering how much might need to be ground down in the back.
It's a little over an inch from the face of section of the bumper that mounts to the frame horn to the outside edge of the light. So closer to 1 1/4 when you get to the actual fins.
Deleted member 12951
Guest
So does it look like if you made your own bracket with the two holes set back 1" further that you would not need to grind any of the fins down? Would 1" make it looks a lot better, or have you already tried a modified bracket?
F
Floyd91
I haven't messed with it. I haven't even put the security bolts on as I figured it would be changed quickly. :ROFLJest:
I think a bracket that's about an inch shorter would bring it pretty close to being tucked.
Guest
I will post back what I end up doing.
F
Floyd91
Awesome. I was contemplating cutting and rewelding the rogue bracket.
Troy just got back to me again and let me know their design team is going to take a look at it as well.
Guest
Great news. I've had nothing but great things to say about Rogue (Ryan is awesome!) and @Baja Designs, great people and great products. Just these two items don't go well together. Rogue listens and if they look at this, they will make it right.
http://www.fordraptorforum.com/f169/rogue-47702/
F
Floyd91
Great news. I've had nothing but great things to say about Rogue (Ryan is awesome!) and Baja Designs, great people and great products. Just these two items don't go well together. Rogue listens and if they look at this, they will make it right.
That's what I'm hoping. There has definitely been a lack of communication, but it's easy to see how that happened now.
Troy.
Hey guys I apologize about the issues you are having. I'm doing my best to get these issues resolved I was not aware of the fitment issue until recently. Unfortunately the reason for this is the frame horns on the Rebel Bumper are in the way of the light and it can not be installed as far back as we would like. With the Renegade Bumper you are required to cut the frame horns which moves the mounting points backwards allowing for a deeper light bar pocket. I'm currently working with my cad designer and Baja designs to come up with a solution. I personally will be in contact with each of you until I resolve this issue. Please feel free to call or email me anytime [email protected]
F
Floyd91
Thank you.
