Rogue Racing Stage 4 23,000 mile update
jlatigo
Spring
After logging over 23,000 miles on this kit on and off road, I've come to the conclusion that this kit has been the best investment in my personal happiness. It has allowed me to run anywhere and everywhere i want at speeds few can keep with, while riding in total comfort and control. The only issues I've had were due to bad alignments. Two different places half assed the work and made the truck always have a slight pull to one side. It was taken to a proper Off road shop and that issue has been resolved, now it drives perfect and similar to a stock truck on mid-perch. During the alignment all the components of this kit were inspected for wear and NON was found. How hard do i run the truck? last outing i broke the steering rack and burned the power steering pump up. This truck is not babied and goes off road at speed at every opportunity(sometimes exiting the freeway at highway speeds through the medians and onto the feeder when needed).
Palerider
My bank account and girlfriend are really going to hate you. Because if I do end up going forward on this I'm putting all the blame on you.
jlatigo
jlatigo
Spring
on a side note, still no axle hope running 37'even after the JDM upgrades to the Roush SC. This is the sprung under setup.
---------- Post added at 11:23 PM ---------- Previous post was at 11:21 PM ----------
do it! life is short, money comes and goes,but great memories made with this kit will last a lifetime!
Palerider
Dammit now I've gotta do it. Who can argue with such logic? Not I!
What exhaust setup are you having to run with the cantilever rear? I plan to go Whipple later on and want to get the exhaust system ready.
ProjecT 9
Houston
Just curious, what's the pros/cons of sprung under and sprung over? Looks awesome man. I'm slowly converting my truck.
jlatigo
jlatigo
Spring
i have the Roush exhaust but i have it routed out the passenger side right behind the step. It needs to be custom bent to clear the spring shackle due to the extreme range of movement of the system.
---------- Post added at 10:17 AM ---------- Previous post was at 10:12 AM ----------
Thanks!
pros- more travel, no axle wrap
cons- ? maybe extra cost?? not really sure, but i'm sure there are some experts on here that can chime in, or maybe Rogue can tell us?
In my opinion, based on my personal experiences owning a couple of other kits and driving a few belonging to close friends, this conversion is well worth the time, money and effort! I haven't driven another truck that does what this does in the comfort and control that this one does.
SC87
Oshkosh, Wisconsin
The only real negative is if you tow. You loose a lot of your towing capacity with sprung under.
Sorry to post on an old thread, but I was curious about the loss of towing ability for both options. I would want to be able to tow my 86 Camaro which itself has a curb weight of ~3,300, plus the trailer would weigh something too.
jlatigo
jlatigo
Spring
truck still tows what a stock setup will
