they’re not a real slider because they still attach to body buckets but they at least use all 3 mounts, they’re steel, gain over an inch of clearance in height and close to 2 inches in projection out and they’re well made, I just ran my truck over an 18” rock that would have tortured the stock steps so I’m very happy with mine
sure pm me an email and I’ll take a few pics
they may not give you what you want, they certainly protect less as far as side impacts and you lose the step unless the door is open, KHC makes steps that may be better for you
Ya I’m happy, stock body mounts, but uses 3, jack carefully!I'm about to buy a set. Are you still happy with them?
I am trying to confirm they bolt to the unibody/pinch welds and not the frame. Based on your comment that seems to be the case. You could probably jack from there, especially where the 1st and 2nd set of mounting bolts are closer together. But a drop and hit on a rock or lock might bend up the mounting location.
I am looking at the kicker slider with top plate. It seems like you could still carefully use it as a step with the door closed, but you lose and inch or two off the stocker steps.
stronger option yes but almost twice as expensive and twice as heavyThis to me is the better option:
Ford F-150 and Raptor 2015-Newer Rock Sliders - White Knuckle Off Road Products
Includes the following features: 101" overall length maximizes coverage of the rocker from flare to flare while allowing for oversize tires 1/4" thick x 2" x 3" rectangular tube main rub rail for greater foundational strength 1/4" thick x 1-1/2" square tube legs to limit flexing while...white-knuckleoffroad.com
