joekai
I don't recall who but for example I have my "SVT" Fender Logos spliced into my front corner marker lights. Once my running lights come on the "SVT" comes on.
I would think it would be that easy... Run your hot for the Background Radiance Lights direct to the marker lights. Then run your hot for the main setup to your Aux switch. Be sure to check your fuse size and make sure it's good.
Things to keep in mind though - by doing this, your background lighting will ALWAYS be on when your running lights are on. You can only shut them down by turning off EVERY light not connected to the AUX switches.
Also - depending on the color of your background light you may not want this option as you don't want the blues-reds always on regardless of how dim they are...
I also have the lighted side vents spliced into the corner LEDs, I didn't know if I should try and splice in to a different power source or not. I'm going with the amber radiance bars so I would imagine I should be safe with the 50' up on the windshield, and the 20" in the lower grill.
Thanks for the info!
