GEN 2 Rigid Radiance scene pod
Vegas_Sirk
Boise, ID
With our fog kit we include a harness that you wire to 4 upfitters (or 3 upfitters and a power source).
Each pair of lights goes to an upfitter
Then there is a "control wire" you'd wire up to another upfitter (or as I said, another power source) which turns the back-light on
https://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-rigid-industries-radiance/
That seems like a lot of used upfitters. I already have a set of the D-SS on Aux 1 so in an ideal situation, I would want all the fogs main lights on 1 switch and then the backlights on another. As I would probably drive around with the backlights on all the time.
4x4TruckLEDs.com
That's up to you. We provide you 4 wires so you can do what you want. If you want to twist 2 pairs together onto 1 upfitter, you can do that. Or if you want to twist 3 pairs together to 1 upfitter, you can do that as well.
3 pairs of Radiance Pods call for 6 amps. So you have 4 upfitters to choose from to power all 3 pairs
3 pairs of Radiance Scenes call for 12 amps. So you could pick from 2 upfitters for those.
But you CAN wire it up that way if you choose.
Phil O
Sacramento, Ca
Do the backlights and main lights wire up separately? For example, would you run the backlights to one upfitter switch and the main lights to the other?
I actually ordered my lights from SpecialtyPerformanceParts and he has a Backlight kit that you install elsewhere so the backlights turn on whenever you turn the truck on. I didn’t want to waste an auxiliary switch for that. It was a simple setup. He also has videos on installing which makes it a breeze. Look up “John Trischler” on YouTube.
Sgt Beavis
Colorado
I actually ordered my lights from SpecialtyPerformanceParts and he has a Backlight kit that you install elsewhere so the backlights turn on whenever you turn the truck on. I didn’t want to waste an auxiliary switch for that. It was a simple setup. He also has videos on installing which makes it a beeeze. Look up “John Trischlet” on YouTube.
I saw that when I was considering the Radiance pods. It's a nice kit and he has a really good youtube video on how to install it. It looked like a simple and elegant solution..
Vegas_Sirk
Boise, ID
Yea that's even a better set up. I'll check it out.
4x4TruckLEDs.com
