I'd go spot, but if your not entirely sure, there's always combo beams as well. But bigg50 is right, there is plenty of light "splash" on spot beams too.
On a side note, I've got a sale going on that includes rigid.
Thanks, advice coming from you BIGG50 is much appreciated. The lightbar is getting installed behind the grill so there should be a fair amount of diffusion just from that. And since I could see myself using this on the highway at times when nobody on the road, the spot seems to be the ticket.
I will get all the flood I need from the low beams on my soon to be installed HID's. It was suggested that I upgrade the HID from 35 watts to 55 watts, but besides the expense, I think that 55 watts might be overkill to the oncoming drivers on these narrow CT roadways.
My next spend will be for tie rods, would rather spend the money there than on additional lights.
One other question. I am getting the perch mod. I am guessing they will install and adjust the HID headlamps and lightbar after the perch mod is done.
