** RETROFIT HEADLIGHTS **-Custom built HID Retrofit pics and pricing
Wilson
South Dakota
Hello all.....Just wanted to help the guys on the fence out and let you know what results I see over the stock 2013 HID's:
1) The standard beam spread is MUCH wider than stock, making for a very nice full range viewing without adding fog lights.
2) Brights work perfectly with the stock set-up and are really impressive as no viewable cutoff is present.
3) The Off Road option is VERY powerful, the regular lights work extremely well in this kit but the higher wattage off roads blast light everywhere. Nice to have this option hooked to an upfitter all while packaged in the standard headlights.
4) The "Evil eye" Halo's are where I really notice something different. I have the white version hooked to a another upfitter for (DRL). Gets a ton of looks during the day...but at night they are so bright you they actually enhance the viewing range. Sound crazy I know, but last night I was driving alone in the center lane on a three lane highway. You can see the outter side barrier walls perfectly through the side windows at a 90 degree angle. I turned off the Halo's and you loose about 10' on the sides. When they are on with the HID's you really get a viewable range unachieveable with any headlight set-up. Great for catching a deer far back off the road, here is Ohio that is VERY common and it's nice to see them that much faster.
Roger at RSiWorks did a great job with these headlight kits, I highly recommend as you will not be disappointed!!
Thanks' for the wright up now I'm even more pumped to get them knowing they are even better than stock hid's. I have a 12 so this will be a even better improvement. That is what I was going for but the look's is a welcome coolness factor.
hamatym
Hudson, OH
Wilson your in for a real treat...Even when the truck and lights are off, it still looks bad ass just sitting there!
Now all I need to do is figure out what to do with the OEM HID's, Roger was kind enough to supply the perfect size box for packaging.
IRONMAN
Well-Known Member
MICHIGAN
how about now? :joke:
I need to buy a side marker light socket so I don't have to keep taking my lights off.
You could say I'm a pro in taking these off.
I'm a bit under the weather other wise I'd get my ass out there now to do it.
