Replacement Tailgate Emblems
602Raptor
Phoenix, AZ
Great idea! Does the backup camera work any differently after moving it? Are the alignment lines on the nav screen still accurate when backing? I'll assume you could use a super duty handle and camera and it would all be plug and play.
jackjare9455
jackjare9455
Longview, TX
the plot thickens! So... His emblems are "pin" style connectors, that only work with that style of camera housing. Apparently, there were two styles, and the other style used "tabs" and if you have that, his emblems will not work.
Also, if you buy his painted base and painted emblem, you have to make sure you also originally had the pin style emblem, because the camera is different between the two styles.
So, the only way that I know, to know, is to go outside and probably snap off my factory blue ford emblem. LOL
Irregular F150
its terrain good sir!
a small town in way up northeast
The lines sit a bit higher, the real pita part is getting it alined while the epoxy dries. I did 2 tries cause the first one was off a bit lol. Good thing the handles aren’t expensive.
Id like to find a camera that was already set up for the handle to try. If that works its be great!!
Gryphon313
Western, WA
2010 F250 rear park assist camera has the tabs for attaching to the handle you used. Not sure if it’s compatible otherwise.
Irregular F150
Edit…
After looking at my oem cable that one wont work. This is the oem cam. Oh well lol
Irregular F150
did you ever find a way and parts to relocate the back-up cam and have it function properly?
I have it epoxied in place still, it ended up moving a tad before fully dry again ughh. But i use it fine. Im waiting on a response to see of theres an all black version. This may work better..hopefully lol
Cam setup
