Recommendations on electric pressure washers that are fairly reliable?
Clinsta
I’ll probably take a beating on this, but Harbor Frieght has an electric power washer that I use out at the ranch to clean the floors in our walk in cooler. It’s used every weekend from October through the end of February. I had to have electric because the primary use is indoors so I bought this to solve a problem not thinking it would be a long term solution. It’s been a workhorse for 3 years now.
https://www.harborfreight.com/home-...pm-corded-electric-pressure-washer-63254.html
Oldfart
Oldfart
I'm wondering if you can put a foam cannon on there? It looks like it may have a proprietary end on it. I have several pieces of HF stuff here I like.
Raptor911
Ashburn, VA
Clinsta
There’s a video on the Harbor Freight site that shows a guy cleaning his vehicle with it. You’re right about the proprietary end on the spray gun. The provided low pressure soap canister seems to work pretty well in the video.
ljn21
Tega Cay, SC
The Kranzle is the best electric power washer you can get and you can only purchase it at Obsessed Garage >> https://www.obsessedgarage.com/apps/productbuilder/complete-kranzle-pressure-washer-configurator.
It is built like a tank. Take care of it will be the last power-washer you buy and you will pass it on to your kids. There are a tons of reviews on YouTube. It has to be one of the most quiet electric power washers out there.
Looka like a Sun Joe, would assume its a 15mm connection vs 14 mm on others (14mm is considered normal)
ljn21
Tega Cay, SC
Pretty sure you can get them other places than Obsessed Garage.
Kit
https://clean-garage.com/kranzle-k1...UrcmdvvLdxIN4aj2bgKceeEgD0quDDAkaApOjEALw_wcB
Just Pressure Washer
https://www.pressurewashersdirect.c...ZCtQs2P8PQI1cdApblAzZ4YWxXLQmD54aAgNpEALw_wcB
Etc.
JohnyPython
Canada
You can get adaptors to convert all your extensions/foam cannon to the same 1/4” quick connect. I had to file my adaptor down to make it work.
Now, the nozzles pop on an off and the foam cannon stays vertical. I even got an underbody sprayer.
I find the best selection to get the adaptors/accessories is AliExpress. It’ll take a while to receive purchases at this time.
In terms of electric washers, I have some portable electric unit for like 20 years now. If I had to get a new one, I would upgrade to a Bertolini.
