Jake17
★ REBEL LIFE ★
- Joined
- Jan 28, 2017
- Posts
- 1,370
- Reaction score
- 548
That is it then, if they remove the squid his lighting will stop causing fires!Squid Lightning!!! Lmao
I understand the Scab has a different B-pillar than the Screw, but I find it hard to believe they use different pretensioners which are the real problem.Nope...just SCREWs and regular cab F150s.
Correct, same tensioner. Their fix is to remove the flammable material, not fix the sparking tensioner.That is it then, if they remove the squid his lighting will stop causing fires!
I'm not affected here, scab . But I still feel they should replace the darn tensioners. Back charge who made the faulty ones. This repair would **** me off.
Another reason I'm glad I bought a SCAB.
What happened to flammability standards? Why does this stuff burn so readily?I don't have a dog in the hunt, but are you serious when you say that the solution to the problem is to remove flammable material in leu of stopping the sparks?
Wow!Correct, same tensioner. Their fix is to remove the flammable material, not fix the sparking tensioner.
The rear door of the SCAB doesn't have all the insulation in it.
@Yukon Joe
[emoji830][emoji830][emoji830][emoji830][emoji830]♡♡♡[emoji830][emoji830][emoji830][emoji830][emoji830]
Donate to a fellow raptor owner
http://www.fordraptorforum.com/showthread.php?p=1286274
