GEN 2 rear window switches not working?
Toadster
Folsom, CA
what would cause the rear doors to not be able to control the window up/down? I can operate them from the driver seat, I checked - it's not the window lock at the driver door... ideas? Forscan?
Toadster
Toadster
Folsom, CA
Child protective turned on?
Yep locks are not set to child, tried the window lock button at the driver door too
Do the rear doors have a fuse to themselves? If so why would the driver switch only work?
jaz13
Try turning the child locks "on" and see what happens.
THUMPER
Toadster,
You recently did sound deadening in your doors ? maybe something knocked loose or pinched. if works from the drivers door ,maybe the circuit for the window lockout is compromised somehow. just a thought buddy
Toadster
Toadster
Folsom, CA
Toadster,
Just weird that the front works but neither rear door has any interaction...
THUMPER
Correct, but what I'm saying is , it's possible the switch is sending false info to body module to lock out windows. I have seen that similar working on BMWs where the switch block in drivers door was the culprit or wiring gotten damaged or even corrosion in door jam where wires pass through(thats mostly older cars) . Have you tried rear windows since the dynomat/speaker install?
THUMPER
