rear view camera
JD 500
Colorado
Zoom
You have to be stopped or only barely moving for the zoom to work.
With that said, when I first got my truck, I never even saw zoom on the screen, then one day I swear it just showed up.
twlhunter65
Well-Known Member
Massachusetts
I have an issue with my rear camera.Not alot buy sometimes when you put it in drive the rear image wont go away untill you stop and go through the shifting again.
Blind1
Central Alabama
I believe Humvee is right and it's set to you rear camera delay settings to shut off after so many seconds, or when you go above 10 mph. At least that is what I have noticed.
Humvee21
Yes you're right. Just for accuracy, the rear camera will disable after 5mph in drive. I like the delay feature when I'm at a traffic light and i pop it into reverse quickly then back out to check out the guy behind me without having my reverse lights on.
Ruger
Northern Nevada
My camera image is good, but the guide lines will not appear. Doesn't matter how many times I set the guide lines to ON, the setting immediately reverts to OFF. I even tried disconnecting the negative battery cable overnight in an attempt to reset the system. That didn't help. The problem remains. Has this happened to anyone else. I like the guide lines!
For reference, this is a 2011 SCAB.
