Real Raptor Specs? (Price, HP/TQ, ect)
Lee358
Wayne, NJ
Anyone know if a light bar will fit behind the grill with the new motor??
bstoner59
does it come in shmedium?
Orange, CA
Typically for specialty vehicles from Ford you are limited to their packages. You cannot pick and choose options.
ovrlnd
Likely, but I'd hoped that Ford's new production line would enable them to customize the Raptors as much as the other models.
Out of curiosity, I went through the options available on a platinum and king ranch just to see what's not listed on the screenshots. Of course some of this stuff might just not have been listed.
So apart from obvious things like colors, engine choices, etc...
No power running boards
No multi-contour seats (though I thought some of the show cars had these)
No active park assist (strange, since all the pieces are there for it)
No box side steps (could probably get them as an accessory if you wanted)
No extended range fuel tank
No max tow package
No trailer tow mirrors
No dynamic hitch assist (I assume it exists, just not listed)
And that's about it. Things like the max tow and power running boards are obvious exclusions. I'd love to have the multi-contour seats - I've sat in them and they'd be awesome on long trips. Hopefully, I can get the big mirrors retrofitted, albeit expensively.
I'm a bit disappointed in the lack of an extended fuel tank option - I'm guessing that the dual exhaust prevents this. But that's something which couldn't be retrofitted practically, so more incentive for ADD to give us a rear bumper with tire and jerry can mounts! :biggrin:
ovrlnd
I went though the standard features on those, and most all of it seems to be included on the Raptor, except what I've listed of course. There are things like power door locks and stuff that I didn't bother listing even though they aren't specifically called out on those screenshots.
I'm slightly suspicious of those screenshots, but only because it looks like the build starts off as a super cab, but then lists options for the dual panel sunroof. But of course it could be that those screenshots are from different builds or could be a glitch in the system, so who knows.
One other thing I just noticed is the lack of cooled seats. But that's another thing that I know I've seen in the show trucks and media pics, so it's a question mark at this point. Actually, there's an option for rear heated seats and a heated steering wheel, but nowhere in the screenshots are heated front seats listed. So clearly we aren't seeing everything in those shots.
SilverBolt
Hired Gun
Portland, OR & Eureka, MT
No max tow package
Most of these make sense why they wouldn't be on the Raptor. Power running boards & box steps will take away ground clearance. Active park assist likely something to do the the width of the vehicle, tire size, and suspension height. The tow stuff the Raptor is not designed as a tow vehicle. Yes it can tow but that is not it's primary purpose. You are probably right on the fuel tank.
Craigy
I really can't imagine that they would forego added fuel capacity for a dual exhaust. The extended tank was such a big hit that they added it as an option to every model except the shortest wheelbase. To drop it on the lineup's biggest gas guzzler, go-anywhere offroader for the sake of a dual exhaust would make no sense.
Ditto though on tow stuff, and running boards/steps.
Mesa, AZ
No max tow package
We got the jerry can mounts already for our bed cages, our chase racks will work with the 17 Raptors.
This configuration holds 40 gallons:
