RDFTS - 2020 GEN2 Build
  • Start date
Guest
So with the components below:
• Deavers +4HD
• RPG +2" Billet Shackles in Orange
Is it correct to state that the +4 HD Deavers would effectively eliminate the rear OEM 2" block while raising the rear 2" and the +2" drop shackle would keep the stock droop?
In other words this would give you an extra 2" of clearance in the rear while keeping the stock suspension travel, correct?
Actually with this setup, I am expecting the rear to be raised 1" over stock because the shackles lower it by 1", not 2". Over time especially when off-roading the leafs will eventually start to sag. Not too much being HD's but I am thinking in 2-3 years it will be pretty close to stock height. I am getting the upgraded Fox coil-overs so I will be raising the front to get it level. And yes with Deavers or ICONs, the factory block is removed and the longer shackles provide more articulation/droop travel over stock.
sixshooter_45
Arnold
Ok, thanks. I guess the OEM drop shackle is a +1 then.
Guest
No stock is the baseline so any aftermarket shackle is referenced to 0”.
If you put these +2’s on stock leafs it would lower it by 1”. Just because the shackle is 2” longer does equate to the exact difference because of how the leaf springs pivot
Guest
Well after delays with my build, I finally just paid a shop to install the big stuff. Had Comal Truck Gear in New Braunfels @treypal and Hudson with TRR/BRR do the work.
Did all the lights that were originally planned but went with 4 LP6’s instead of 6.
Rear with GJ brake light and S1’s below the bumper
RPG bumper came out nicely with the Wagner IC
Lights with the LVJ panel
Front suspension, ICON UCA, FMS slot deletes with Fox Live upgrades
sixshooter_45
Arnold
Yep. Button allows me to flip on or off all the front facing lights with the factory hi-beams. The amber backlights in the LP6’s are tied into the running lights
1.) So how did you exactly tie into the high beams since so many folks want to do this, however, everything I've read stated it would cause issues.
Please see this thread below:
Alternative-High-Beam-Connection
2.) Did you have to get or do you have a ham operators license, I'd love to get one but don't want to agree to government warrantless searches to get a ham operators license.
Very nice upgrades by the way.
Guest
Upgrades are all purpose built. No ******** mods like bigger wheels, carbon fiber, etc..
Info on the hi-beam panel
If the government wants to come after me for a radio that will mainly used off-road, they can come and get me.
