Mine does this too. I think its pretty normal. You have to wait till it idles down and warms up. Otherwise it surges and won't go between 10-15, jumps above that.
How long do you let it sit before you drive? I've let it sit for quite some time after the idle has dropped to normal and still the same issue. I'll let it sit in the garage for 10 minutes later tonight and see if the problem occurs.
Have you ever looked into it? A guy I work with has the same truck, same year, and never had an issue. If he doesn't have the problem and we do, that is a bug/problem with our trucks.
If this is really normal for my truck I might have to return it to the dealer and say keep it unless they can fix it. A year of this "jerking" on the tranny can't be good for it.. I bet it would lead to more severe issues.
---------- Post added at 05:41 PM ---------- Previous post was at 05:35 PM ----------
Another thing I noticed tonight is that it does it if I'm in 2nd gear as well...so issue occurs when the stick is in 1st or 2nd. Doesn't appear to be a shifting issue.
---------- Post added at 05:43 PM ---------- Previous post was at 05:41 PM ----------
Looks like these guys are having the same issue:
2012 F150 5.0 crew 4x4 low speed surging - Page 2 - Ford F150 Forum - Community of Ford Truck Fans
---------- Post added at 05:47 PM ---------- Previous post was at 05:43 PM ----------
A lot of guys in that thread think it's the retarded timing that ford does on startup(-12 to -15). The timing then swaps back, but i'm not sure if that's my issue or not:
2012 Ford F-150 5.0 Ignition Timing Retarded 9* Causing Rough Idle On Start Up - YouTube
