Raptor TCM Support is Now Available!
rayofsi
NYC
Now access port manager is offline and my access port says to eject before disconnecting which I can’t do. I want to smash this thing!!!!!
After the license key update. You don't need to dodownlo anything. Just update the accessport.
Raptorrunner2019
Wewahitchka
I’m going to give it another try this morning
Also Cobb had some pretty good directions step by step
1. Download the upgrade.key attachment into a folder of your choice.
2. Connect your Accessport to your computer.
3a. Update to the latest version of Accessport Manager (APM).
3b. Update to the latest firmware for your Accessport.
4. From within APM, go to the Options menu, and click the "Advanced" button.
5. From within APM, click the "Change Accessport License" button.
6. Browse to the folder where you saved your upgrade.key, select it, and click OK.
7. The process is complete when you see and confirm the success message. Your Accessport will now reboot and the feature will be active.
You cannot see the files until you hook the access port up to the truck for the first time. Complete a backup of the original stock file before applying tune. It will ask you When you select your desired tune too. Good luck.
sys999
USA
Well worth it. Sport mode matches capability of stage 2 aggressive 93 tune nicely. Sport plus truck's "normal" mode is what I've driven thus far. It rows through all the gears, downshifts to the right gear at all intermediate levels of throttle, and doesn't hold onto gears forever like stock Sport mode. Also, thank God I don't have a 10th gear upshift coasting at 45 MPH any more.
Wfo
Syracuse
I followed the instructions. When I connect to truck it states that TCM is not supported my my model. I tried to reload license and get “key has already been used with this access port”.
Raptorrunner2019
Wewahitchka
Oh wow. That sounds like you did everything right, not a computer issue. It may have something to do with the vehicle and/or Cobb. I am sure they will help you.
JohnyPython
Canada
I’m gonna get the TCM update. Monday is the last day for the sale.
Looking for a review on the TCM tune.
twelvesecsst
Utah
I haven’t gotten super aggressive with it yet, but I tested out the OEM+ in normal and sport mode on the way home yesterday.
Normal is subtle but noticeably smoother under acceleration (light and heavy).
Sport is WAY smoother with no abrupt or hunting shifts, including the harsh 4-5.
In both modes, the truck feels like it has to work less when I give it gas and picks ups the acceleration much faster.
I’ll report back when I get some time to do more spirited driving with the Sport TCM mode, but through the otter threads there have been some other reviews as well.
I have a goosetuned stage 1 ECM and they go together very well.
Dustan
Boulder Colorado
Try doing a TCM reflash again (use the change map feature, you don't need to select a different map) - make sure that you wait the full amount of time after the flash with the key off! If that does not resolve the issue, send in an email to [email protected] and we'll work with you to find a solution.
So are you saying that 2017 and 2018 trucks will get up hill assist with the 2019 tcm flash? One other question I have is does the transmission tune only effect normal and sport modes or are the other modes changed. Thanks for all the work Cobb. I never had any big issues with my transmission but after running the stage 2 set up for 10 months and having no issues I had to give this a try.
