So if seems that this Adam's place sells the stuff I need. Does anyone have a short list of must haves to get from there? I don't want to spend all day on the website trying to figure out what I need for the Raptor.
Car Wash Shampoo - need to use pH neutral soap so you don't strip off the sealants or wax. I use the
Wash Wedge, but you can also use a
Wash Pad. It is good practice to use two, one for the upper 2/3 of the truck where there is less dirt (usually), then a second one on the lower 1/3. A good way to keep them straight is to use the Wedge on the upper, and the pad on the lower.
Detail Spray - aids in drying, adds some shine. Use a good quality microfiber
waffle weave towel for drying. Do not use cotton towels, they scratch.
Quick Sealant - covered pretty well in this thread, just make sure you always level it out with a
foam applicator or a microfiber towel before it dries. For most areas, I spray the applicator and then use that to apply to the surface, other complex areas like the grill and wheels, I spray directly on the surface, then use a towel to level it. A little goes a long way. Do not spray so heavy that you get drips. Definitely watch the
video on this product.
Liquid Paint Sealant - a long lasting layer of protection, makes cleaning much easier. Apply with a
Hex Grip Applicator, remove the haze with plush microfiber towels like the
Double Soft or the
Borderless Gray.
Tire Shine - looks good, keeps the tires sealed up so they don't get stained with mud. Apply with the
Pro Tire Hex Grip Applicator.
The most recent
videos are on AdamsPolishes.com but you can also search on Youtube for older videos that cover additional products.
