Raptor Powered 2019 Limited...
Oldfart
Makes sense. I asked as I was under the impression the raptor engine and the gt engine were similar, but makes better sense seeing the same engines used just tweaked for the high performance platforms. Thanks for the info!
There's been several guys here that used the Limited muffler on their Raptor to quiet the truck down a little more. Apparently, it flows the same, but is quieter.
ADucatelli
Dallas, TX
Hey @Kurtj29
Nice to meet you! I have a 2019 Limited as well; glad to see there are a couple of us misfits here! ;)
I’m running a few mods on mine, happy to answer any questions about them:
- Cobb Accessport V3 ECU & TCM (Stage 1 ECU, OEM+ on TCM)
- AFE Quantum Intake Scoop
- Rousch Intake
- AMS Boost Tubes
- SPD Turbo Adapters
- JLT 3.0 Catch Can w/ Extension
- SP-9100 w/ SDHQ Mount
- GJ Third Brake Light w/ 3x Baja S2 Pros
- (2) Squadron Pros for Fog Lights w/ Baja Mount
- AutoStartStopEliminator
- BGGDesigns Spot Lamp Override
- Other Interior QoL Upgrades
Plus, I’m putting on these this weekend:
- 285/55r22 Nitto Ridge Grapplers
- Fox 2.0 Stage 1 Kit
- Full Race v2 FMIC
- Upping to Cobb Stage 2 on ECU
Muchmore
Kansas City
Unless the limited comes with 4.10 gears, I wouldn't plan on running raptor size tires if you want to keep the fire breathing power.
As long as the overall tire diameter is the same it won't change.
BlueWhale
CA
Hey @Kurtj29
- Rousch Intake
- AMS Boost Tubes
- Full Race v2 FMIC
Nice, please post some pics when done.
PlainJane
San Diego, California
The "real" bead lock rings would look funny with the tire mounted inside in the normal location. The ring stick out about 1" from the rim because the bead of the tire is outside the rim and inside the ring.
Nohowtoplz
Illinois
I had to look it up for myself, I thought it was just the ‘20 that they did it to start, but it was ‘19 that got the HO 3.5 in it standard.
Yes the '19 Limited had the HO 3.5. I traded my '19 Limited for my '21 Raptor. I was disappointed to find out the off the line speed differences between the two was like the tortoise and the hare.
Badgertits
Ma
The Limited has an arguably better exhaust then the Raptor, to go along with the same engine.
I’m very interested in seeing the Raptor wheels on your Limited. It’s a very good looking truck. The Raptor 17’s will definitely improve the ride over the 22’s.
Ahhh how are they gonna fit w/o a lift?
