mberger111
I think 2015 and newer it shows even without doing that based on the video. Also if you press + or - you are in manual mode. My wifes Edge Sport does the same thing. If you select M then you are forced to manually shift, but if you are in D and use the paddles to shift up or down, you go into manual mode.
The truck saves it from one drive to the next. That could be the case, who knows but if it's like a 14 that is how it works. However, I do know simply hitting +/- in drive will not put it into manual mode. It locks gears out which is pretty nice to have seperate from manual mode.
---------- Post added at 08:11 PM ---------- Previous post was at 08:07 PM ----------
Anyway, you could be right but the video doesn't show that.
