Raptor Air Oil Catch Can
Dv8tor
Detroit, MI
Looks good but why run regular hose clamps instead of the factory PCV connectors?
If I can get them, I'll do that. I kinda butchered the PCV Valve and Vent Valve by shaving the nipples because the hose the guy gave me was too small. I just shoved the hose on as much as I could. But I'm kinda afraid of the hose popping off so I bought those ****** hose clamps. Those connectors are nice. I'll look into getting them. On a side note, yes I am NA. Ready for a blower in the future possibly. Surprisingly when I pulled off the drivers factory Vent hose, there was a lil bit of oil and some very very tiny dirt like debris. Passenger side definitely had oil in it. It might have been in the beginning of the connector where debris can get in. O well. I was going for a "factory look without having to drill holes in my truck. I used brass fittings. The stand off bracket I made out of Aluminum that I bought at Home Depot and shot the bracket with Rustolium Gloss Black because the JLT bracket is is goss black so I wanted it to match. Used stainless hardware as well.
SVTRay
I'm not sure about the individual connector but you can buy the complete factory hose/connectors for $16.48 through Ford. I can post the instructions on how to remove the connectors right now but there is some posted in this thread...Look for the Moroso install instruction link. It's real simple, you use a razor blade to cut the hose off.
2010 Ford F-150 PCV Valve Hose | FordParts.com
Dv8tor
Detroit, MI
I do like that idea much better than what I did. I'll have to do that when I get back from FL. Annual FL Tow Show in Orlando this weekend. I f'ing hate flying.
svtchris1021
Calexico, CA
are JLT can still available?! im very interested since today i pop the hood to clean the air filter and saw oil stains on the valve cover! coming from the intake hose :/
Dv8tor
Detroit, MI
Im sitting at the airport. F'ing plane broke. Hour an half delay. I just realized that I ****** up and plumbed the passenger side can backwards. Im going to spin the can 180 degrees when I get back. Fockin' hell! I hope this Vaca is going to be a good one.
SVTRay
Damn, That blows...hopefully it gets better.
Members online
96,364
60,273
NTXRaptor
Latest posts
