wheel weight matrix
Disclaimer - this isn't a list of every wheel available, it is a list of wheels that in my subjective opinion, are appropriate for the Raptor. If it looks like it belongs on an escalade, it won't be on this list.
SVT wheel 17x8.5
Offset: 34mm
Backspacing: 6.18" Bolt Pattern: 6-135
Rec. Tire Size:315/70-17
Weight: 31.5lbs
ATX Artillery 17x9
Flat Black
Offset: -12mm
Backspacing: 4.48" Bolt Pattern: 6-135
Weight: 30.2lbs.
**** Cepek DC2 17x9
Offset: -12mm
Backspacing: 4.56" Bolt Pattern: 6-135
Weight: 24.8lbs
**** Cepek Torque 17x8.5
Offset: 6mm
Backspacing: 5.04" Bolt Pattern: 6-135
Weight: 24.8lbs
Ultra Nomad 17x9
Offset: +25mm
Backspacing: 5.98" Bolt Pattern: 6-135
Weight: 25.2lbs
Method Forged Truck Beadlock 17x8.5
Backspace 4.5" Bolt Pattern: Blank - made to order
Weight: 27.8lbs
Method Truck Non Beadlock 17x8.5
Weight: 27.5lbs
Method Truck Beadlock 17x9
Backspace: 4.5" Bolt Pattern: Blank - made to order
Weight: 33lbs
TrailReady Beadlock HD17 17x8.5
Backspace: 4.5" Bolt Pattern: 6x135mm
Weight: 34lbs
TrailReady BeadLOOK HD17 17x8
Weight: 31lbs
Centerline Wilderness Vector 17x9
Backspace: 5.25"
Weight: 21lbs
American Racing ATX Mojave (AX9816) Teflon 17x8
Backspace: 4.5"
Weight: 31lbs
Pro Comp 7033 17x9
Backspace: 4.5"
Weight: 27lbs
Eagle Alloy Series 101 17x9
Backspace: 4 5/8"
Offset: -8
Weight: 27lbs
Eagle Alloy Series 058 17x8
Backspace: 4.5"
Offset: +2
Weight: 25lbs
Eagle Alloy Series 063 17x9
Backspace: 4.5"
Offset: -12
Weight: 29.3lbs
Eagle Alloy Series 100 17x9
Backspace: 4.625"
Offset: -8
Weight: 25lbs
Eagle Alloy Series 140 17x8
Backspace: 4.517"
Offset: +2
Weight: 29lbs
Eagle Alloy Series 185 17x9
Backspace: 4.625"
Offset: -8
Weight: 27lbs
Mickey Thompson's Classic Locks 17x9
Backspace: 5.5"
Offset: -12
Weight: 26lbs.
This is a work in progress, I'll add more wheels as I get the data.
Do you happen to know the weight of Weld Racing's new Rekon line? Typically their wheels are some of the lightest on the market
Got ahold of Weld today, the B57B is a porky 38 lbs. a real disappointment, as I would have loved to ran these wheels if they were >25lbs each.Do you happen to know the weight of Weld Racing's new Rekon line? Typically their wheels are some of the lightest on the market
