Raptor Aftermarket Wheel Weights
WarSurfer
DC
wheel weight matrix
Disclaimer - this isn't a list of every wheel available, it is a list of wheels that in my subjective opinion, are appropriate for the Raptor. If it looks like it belongs on an escalade, it won't be on this list.
SVT wheel 17x8.5
Offset: 34mm
Backspacing: 6.18" Bolt Pattern: 6-135
Rec. Tire Size:315/70-17
Weight: 31.5lbs
ATX Artillery 17x9
Flat Black
Offset: -12mm
Backspacing: 4.48" Bolt Pattern: 6-135
Weight: 30.2lbs.
**** Cepek DC2 17x9
Offset: -12mm
Backspacing: 4.56" Bolt Pattern: 6-135
Weight: 24.8lbs
**** Cepek Torque 17x8.5
Offset: 6mm
Backspacing: 5.04" Bolt Pattern: 6-135
Weight: 24.8lbs
Ultra Nomad 17x9
Offset: +25mm
Backspacing: 5.98" Bolt Pattern: 6-135
Weight: 25.2lbs
Method Forged Truck Beadlock 17x8.5
Backspace 4.5" Bolt Pattern: Blank - made to order
Weight: 27.8lbs
Method Truck Non Beadlock 17x8.5
Weight: 27.5lbs
Method Truck Beadlock 17x9
Backspace: 4.5" Bolt Pattern: Blank - made to order
Weight: 33lbs
TrailReady Beadlock HD17 17x8.5
Backspace: 4.5" Bolt Pattern: 6x135mm
Weight: 34lbs
TrailReady BeadLOOK HD17 17x8
Weight: 31lbs
Centerline Wilderness Vector 17x9
Backspace: 5.25"
Weight: 21lbs
American Racing ATX Mojave (AX9816) Teflon 17x8
Backspace: 4.5"
Weight: 31lbs
Pro Comp 7033 17x9
Backspace: 4.5"
Weight: 27lbs
Eagle Alloy Series 101 17x9
Backspace: 4 5/8"
Offset: -8
Weight: 27lbs
Eagle Alloy Series 058 17x8
Backspace: 4.5"
Offset: +2
Weight: 25lbs
Eagle Alloy Series 063 17x9
Backspace: 4.5"
Offset: -12
Weight: 29.3lbs
Eagle Alloy Series 100 17x9
Backspace: 4.625"
Offset: -8
Weight: 25lbs
Eagle Alloy Series 140 17x8
Backspace: 4.517"
Offset: +2
Weight: 29lbs
Eagle Alloy Series 185 17x9
Backspace: 4.625"
Offset: -8
Weight: 27lbs
Mickey Thompson's Classic Locks 17x9
Backspace: 5.5"
Offset: -12
Weight: 26lbs.
This is a work in progress, I'll add more wheels as I get the data.
WarSurfer
WarSurfer
DC
Cool 16lbs lighter than stock right now.
Per corner or all together? Lighter is better either way.
I'm trying to get my head around the cost of the Baja T/A's combined with the TR Beadlocks - 5k in total but a reduction of 40lbs of rotating mass. That would 'feel' like losing ~350lbs!!!
That could mean decent mpg's as well, maybe that's how I'll pitch it to the wife :)
SilverBolt
Hired Gun
Portland, OR & Eureka, MT
I'm trying to get my head around the cost of the Baja T/A's combined with the TR Beadlocks - 5k in total but a reduction of 60lbs of rotating mass. That would 'feel' like losing ~500lbs!!!
War,
If you truly don't need beadlocks don't go down that road. When you need them you have to have them. For daily driving they plain suck. Constant retorquing, some leak, tough to balance, debrie gets trapped and throws things out of balance, etc. They may look cool but unless you need the beadlock feature you may want to look at alternatives.
WarSurfer
WarSurfer
DC
War,
They also have beadlooks, they look exactly like locks but are one piece. I don't know the weight difference off hand though.
RPG
Orange County
War,
I'm running real Method beadlocks and have put thousands of miles on them since mounted up. After the initial torquing, I retorqued them at 100miles and only a few needed adjustment. Since then, not one has been out of torque. I honestly don't think about it anymore. Also, if you get a manufactured beadlock from Method, or many of the other usual suspects, they are machined perfect and balance with no issues. My truck drives perfect. No shudder on the highway at any speed and no leaks at all.
But Silverbolt is right, they are a bit overkill for daily driving.
WarSurfer
WarSurfer
DC
I checked with TrailReady - the LOCKS are 34lbs, the LOOKS are 31lbs. I'm updating the post.
