GregFoutz
- Joined
- Apr 13, 2013
- Posts
- 39
- Reaction score
- 71
Hey Guys
we just got our Ranger Raptor adjustable bump stop kits finished and releasing now. Several people have been asking about these so I thought it would be best to post it in the forum for everyone to see.
We have a front kit that will work with the stock front lower arm that has a clamp mount that goes on the arm that gives you the bump pad and also limit strap mount. The bump stop mounts to the frame and is a weld on mount kit but you can use Fox, King, ADS, or Carbon 2"threaded body bump stops. Very similar to our F150 Raptor and Bronco Raptor kits.
The rear kit also uses the same bump options with a Fox, King, ADS, or Carbon 2" threaded body bump stop that can be adjusted in height to help if you want to run a bigger tire to keep it out of the upper fender well. The mount bolts to the frame with existing holes. The lower bump pad bolts to the stock rear axle for the bump pad section. Easy install but does require a small trim on the under bed sheet metal that crosses over between the fender wells. very minor but has to be trimmed.
you can check them out here for more info. First production runs are going though the shop right now so these will start shipping first batch in the next 2 weeks but we have a very limited quantity in that first run. We will do more on the next batch but the first group will go fast so if you have been waiting for these i would suggest you jump in quick and get your orders in.
https://www.foutzmotorsports.com/co.../2024-ranger-raptor-adjustable-rear-bump-stop
https://www.foutzmotorsports.com/co...r-front-limit-strap-bump-stop-stock-lower-arm
