Patent pending
Rack:ONE
Mounting Systems
by WSI
Rack:ONE is a fully modular mounting system, currently designed for use in truck beds. WSI will be showcasing products for the off-road market, however we have numerous prototypes and designs for industrial/fleet applications. If you are a fleet purchaser and interested , please contact us!
The main goal of this system, is to alleviate some of the costs of custom bed racks, as well as give individuals the ability to quickly revert back to a pick up truck and use the truck bed as intended.
Main features
-Mounts in the bottom of your bed using existing Ford or Toyota bed bolts, GM and Dodge Pickups will be required to drill 4 holes, with provided drill bit
-Coated with Linex Ultra
-numerous attachments
-each accessory will come with appropriate hardware
-more to come
"Base" comes with
- Ultra Linex'd, Rack:ONE
-A tool pouch
-Install tool
-10 nut-serts
-10 marker plugs
-small wire brush
-1/2'' drill bit (for Dodge and GM only)
A few notes:
- A patent pending has been filed with the USPTO
- We have an aluminum version
-There will be a slide-out version as well
Currently have models for
- Ford f-150 5.5' beds
- Toyota Tundra 5.5' beds
- GM 1500 5.5' beds
- Ford Transit Vans
Products will be on our website shortly
WSIFabrication.com
Thank you
Rack:ONE
Mounting Systems
by WSI
Main features
-more to come
"Base" comes with
-A tool pouch
-Install tool
-10 nut-serts
-10 marker plugs
-small wire brush
A few notes:
- GM 1500 5.5' beds
- Ford Transit Vans
WSIFabrication.com
Thank you
