GEN 1 Quick Disconnects-Pressure washer, Foam Cannon
ddpt
Looking for various quick disconnects (QD), from pressure washer outlet QD to pressure washer hose, then QD to spray gun, then QD from foam cannon connected to spray gun and also QD from spray wand to spray gun.
Have the connections for QD from garden hose to house spigot and garden hose to pressure washer inlet. Found these at HD.
Need QD from pressure washer outlet all the way to foam cannon and spray wand.
Pressure washer outlet is a 3/8" threaded male.
Any help is greatly appreciated
Pic below is outlet from Pressure washer
Sent from my SM-N960U1 using Tapatalk
Kahuna
THE MORE YOU PLAY WITH IT, THE BIGGER IT GETS
Amazon has it all. Just remember gas and electric pressure washer nipples underneath the thread are different sizes. One is 14mm (from memory, gas), one is 15mm (electric).
ddpt
ddpt
I am sure Amazon does but figuring out exactly what is needed is the challenge.
I did go to obsessed garage and he has many of the parts needed.
Pure745
Orange County
Go to obsessedgarage.com he literally tested all these electric pressure washers and has developed kits for quick disconnects etc. I think there's a list sorted by model and it tells you what to buy.
roscopeeco78
I bought all my stuff from obsessed garage. You can find stuff cheaper but he will have everything you need. Make sure you use thread tape to seal any connections with threads. If you think of it in terms of make and female adapters it will be easier.
95,404
58,973
Kwazyace
