Questionable Noise
Zach Gen3
Any answers on what fixed it for you guys? I'm having a similar issue with a light grinding and fluttering noise coming from the front of my 2024. Mostly at low speed turns. Similar to a bunch of you guys, its better and worse on random days. This morning seemed to be the worst its been and that was inside a parking garage at low speeds. I assume it is the IWE, just had new wheels put on last week and shop didn't notice anything out of the ordinary.
Cobber
Spokane, WA
Any updates?, I have a 2017, only owner, I've been having the same issue for quite a while, very intermittent. Always at very low speed, usually as coasting to a stop. As far as IWE, I switched out the iwe valve, jacked the truck up and pressure checked front wheel lines, pressure held, vacuum tank had pressure. Very mild hum, grind that you can feel, not the rattle a bad IWE makes. Of course never does it for the dealer, does it more often when truck is cold. Hard to put in AWD as going slow to a stop and when I take off it doesn't do it. Does feel like something not engaging or disengaging fully. Not sure what else it could be other than the transmission.
