Question on stereo/sync system??
Oldfart
Oldfart
Why do you need a waterproof USB? Nevermind, I don't want to know.
You should maybe pull out every now and then.
No IDEA!! I was surprised when I saw that was a feature. Maybe in case you forget it's in your pocket and throw it in the wash? I like it because it's so tiny, it's only about a 1/2 X 3/4".
I've always hated pulling out!
melvimbe
I definitely feel inadequate if you think 3 feet 4 inches is tiny.
I hadn't even thought of listening to music from a USB. Then again, I haven't loaded music onto a USB for at least 10 years.
Streaming services doesn't play some of the obscure stuff I like, so a USB is useful for that. I can't say I do or do not have Oldfart's issues, specifically with Sync/USB, because I have an aftermarket system and don't use sync like that.
Oldfart
Oldfart
yes 3 foot is a pretty big USB! :Big Laugh: The sound quality is MUCH better if you record a CD in WAV lossless format to a USB. I have 160 cd's on it and lots of room left. It's a noticeable difference in sound quality.
Oldfart
Oldfart
I thought I would post the solution I found in case anyone else runs into this. I ended up deleting/resetting the "Media index" in the Sync system and afterwards it hasn't acted up anymore. It only takes 2 minutes once you know that's the issue. This is the same fix if you add new music to the USB, Sync will not recognize it unless you reset the media index.
